Cruise Control??, sticking accel cable.... |
SGB |
Mar 14 2005, 09:57 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Whenever I mess with the throttle cable from the engine compartment (like to rve engine), the clevis pin assembly up at the gas pedal gets hung on the clutch cable clevis pin or attachment point simehow. In the center tunnel, is the throttle cable closer to the driver, or the clutch cable? It appears that the throttle cable falls onto the clutch cable and slips over toward the driver. What is the right order for these cables? Throttle then clutch (left to right)?
p914 |
Mar 14 2005, 11:29 AM
Senior Member Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
You may try adjusting the floor board at the gas pedal. Sometimes it makes contact with the pedal assembly.
Lo-Fi Version | Time is now: 2nd June 2024 - 06:21 AM |
