seat belts |
seat belts |
80cap |
Dec 19 2015, 03:08 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Is there a thread on how to refurbish retractable seat belts?
Mine are out of a 1976 car and are dirty and fully retracted. I can't get them to release. Thanks Brian (IMG:style_emoticons/default/screwy.gif) |
cary |
Dec 19 2015, 07:44 PM
Seatbelt Planet ................
Consensus is, not worth risking your life. |
ClayPerrine |
Dec 19 2015, 07:54 PM
Life's been good to me so far..... Group: Admin Posts: 15,515 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Go to your friendly Porsche parts house and order replacement seat belts for a 944. They are a bolt in replacement. You only have to open up the hole for the pin with a drill.
GregAmy |
Dec 19 2015, 09:45 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
rjames |
Dec 19 2015, 11:17 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
RenoRoger |
Dec 20 2015, 12:22 AM
Member Group: Members Posts: 95 Joined: 11-November 10 From: Reno, NV Member No.: 12,370 Region Association: Northern California |
Go to your friendly Porsche parts house and order replacement seat belts for a 944. They are a bolt in replacement. You only have to open up the hole for the pin with a drill. Pretty sure they are NLA. Aren't the 914 belts identical to those used for VW Beetles of the same vintage? They should still be available new from decent aftermarket suppliers. |
bdstone914 |
Dec 20 2015, 05:25 AM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Go to your friendly Porsche parts house and order replacement seat belts for a 944. They are a bolt in replacement. You only have to open up the hole for the pin with a drill. Pretty sure they are NLA. Aren't the 914 belts identical to those used for VW Beetles of the same vintage? They should still be available new from decent aftermarket suppliers. Not the same belt as a beetle they have longer belts due to higher seats. i have cleaned them and reused . them. hold them against a verticle surface to get them to extend. temove the cap that does not have the coiled spring. clean and lube. not that much to them. |
EdwardBlume |
Dec 20 2015, 08:57 AM
Lo-Fi Version | Time is now: 8th June 2024 - 07:59 AM |
