door end caps, plugging the holes |
23e Heure |
Jan 11 2016, 09:19 AM
Busy overtaking 911s Group: Members Posts: 323 Joined: 13-August 15 From: London Member No.: 19,057 Region Association: England |
Both my doors are missing a seal / trim.
Car is a 74 build. The trailing top corner of the driver's door looks like this: (IMG:http://www.914world.com/bbs2/uploads_offsite/i13.photobucket.com-19057-1452525561.1.jpg)] Do I need: A) Pair of these:http://shop.914rubber.com/914-Early-door-e...aps-914EDEC.htm B) Pair of these: http://shop.914rubber.com/914-Late-door-en...ght-914LDEC.htm C) Pair of these:http://914er-shop.de/en/rubber-plastic/end...eal-73-76-right D) Something else? Thanks! |
LowBridge |
Jan 11 2016, 09:29 AM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
I have a 75 and used "B" with Marks recommendation and they fit like a glove
rhodyguy |
Jan 11 2016, 09:51 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Order new outer rubber scraper/seals too. Your's will prob be too short and the end caps would need to be removed to install them. As you're in the UK make a comprehensive list of seals and order them all at the same time. Buying and shipping items individually will blow up your budget. There's going to be a lot of little items as well as the big ones. WOW! 45 eu is quite dear for a single end cap.
Other items? The 2 seals for each door/inner fuzzy strips/ triangle Windows, the 2 round pieces for the holes in the door jams, vert and horizontal window seals, side mirror base seals, the ones for the door handles, boot and bonnet seals, various seals for lights and lenses, fender to cowl....the list grows quickly. What kind of condition is your carpet set in? I'm here to help you spend your money. (IMG:style_emoticons/default/biggrin.gif) |
914Sixer |
Jan 11 2016, 06:26 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
914Rubber.com
Mikey914 |
Jan 12 2016, 12:44 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The hole is actually desired to use the screw to hold the "flap" of the door end cap.
Yes you more than likely would want to replace the rear fuzzies on the door track as the other flap is secured in there with the screw that holds it. |
Mikey914 |
Jan 12 2016, 12:48 PM
The outer scraper you have looks a little strange. It looks like the aluminum track that holds the scraper and the inner fuzzy is missing and a generic seal was shoved in there.
I do make the metal tracks if you need them $38 a set. Not listed on the website as they are a little labor intensive to make and I have yet to get enough back stock to list them. Please post some more picks of your set up it looks interesting. |
Lo-Fi Version | Time is now: 12th June 2024 - 01:03 AM |
