Weber IDF Updated Venturi kit from CB Performance |
andrew15 |
Jan 18 2016, 04:46 PM
Newbie Group: Members Posts: 40 Joined: 10-April 10 From: Thunder Bay, ON Member No.: 11,594 Region Association: None |
euro911 |
Jan 18 2016, 06:48 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
What are these for? ... IDF 40's, 44's?
Sizes of tubes and jets? Also, what size are the vents? Thanks ... |
andrew15 |
Jan 18 2016, 08:32 PM
These are for the 40IDF (OD of the main venturi is about 42mm)
The air jets are 175 The mains are 165 Each hole on the crosstube venturi is about 1.5mm Hope that helps AM |
andrew15 |
Jan 21 2016, 10:49 AM
$45 shipped!
pilothyer |
Jan 21 2016, 03:44 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Seems to me these are for the 44 IDFs, can you double check?
B2524 |
Jan 21 2016, 03:57 PM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
i'll take them.
andrew15 |
Jan 21 2016, 06:20 PM
pilothyer - I'm pretty sure they are for the 40mm IDF - the OD of the venturi is about 41.85mm and the id is 40mm and chokes down to 37.5mm
B2524 - Sending a PM |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:15 PM |
