Sound insulation?, ok to fit behind seat backpad |
porschetub |
Jan 29 2016, 01:04 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Don't want a soundpad in my enginebay,is it simply enough to fit it behind the seat backpad with out compromising how that fits?
Material I have is around 5mm thick,backpad not out yet so just asking in advance, (IMG:style_emoticons/default/beerchug.gif) |
jack20 |
Jan 29 2016, 03:25 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Don't want a soundpad in my enginebay,is it simply enough to fit it behind the seat backpad with out compromising how that fits? Material I have is around 5mm thick,backpad not out yet so just asking in advance, (IMG:style_emoticons/default/beerchug.gif) I lined my rear interior firewall with Dynamat and placed the stock molded rubberized pad over the dynamat. I used spray contact cement to hold it place. The backpad went back in without difficulty. Hope this helps. |
rhodyguy |
Jan 29 2016, 03:36 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The lower pass side of the engine compartment pad, If that's what you mean, might be loaded with battery acid residue. Moving it to the interior might not be a good idea.
mepstein |
Jan 29 2016, 03:43 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I took the heavy stock rubber pad off the interior side of the car and will replace it with a modern dynamite/fatmat type pad and then the stock foam and vinyl back pad. No engine side pad will be used.
Chris914n6 |
Jan 29 2016, 07:45 PM
Jackstands are my life. Group: Members Posts: 3,338 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Under the rear carpet is good too. Sound bounces off the pavement.
boxsterfan |
Jan 30 2016, 06:56 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Most take the stock rubber pad from the engine bay and.....throw it in the trash.
There's quite a few on here that have lined their complete interiors with dynamat/fatmat with stated success. |
porschetub |
Feb 2 2016, 03:40 PM
Most take the stock rubber pad from the engine bay and.....throw it in the trash. There's quite a few on here that have lined their complete interiors with dynamat/fatmat with stated success. Cars a -6 conversion had no intention of using enginebay pad anyway,dyna matting the whole the interior is not my thing too much weight added,I don't want the car heavier and have removed weight where ever practical. Cheers for the comments sounds like it will work for me. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:07 AM |
