New headlight relay wiring? |
SKL1 |
Feb 7 2016, 10:07 AM
Senior Member Group: Members Posts: 1,608 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Replacing the headlight relay (for low-hi beams- the square one on end of fuse panel) and it has an extra tab #30 which the original doesn't have. What wire goes to this?
Does it need power now? When I pull the wand to switch from lo to hi beams, nothing happens. TIA. |
SKL1 |
Feb 7 2016, 03:52 PM
FYI- jumper from pin 56 to pin 30 makes everything work... with the new relay.
Lo-Fi Version | Time is now: 12th June 2024 - 06:42 AM |
