Rubber Shock/Strut Bumpers, Needed Or Not With KYBs? |
Ansbacher |
Mar 5 2016, 05:18 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
When using gas shocks like KYBs (please I know their hard and no one like them) do you use the rubber bumper that goes inside the strut dust cover? I keep reading they are "not required" for gas shocks, but does "not required" mean you might use them or not?? Or is it absolutely that you do not use the bumper with gas shocks?
I do understand they are absolutely required for oil shocks, like Boges. Want to order some parts, so hope someone can enlighten me on this. Thanks. Ansbacher |
injunmort |
Mar 5 2016, 06:39 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
i use them as an added layer of protection weather they are called for or not.
screenguy914 |
Mar 5 2016, 08:35 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Any rubber bumper positioned between the chassis mount and the shock body acts as a compressible bump stop in case the chassis is lowered close enough to bottom out the shock at full compression.
If your vehicle is lowered that much, consider shortening the shock stem to avoid shock damage. Of course that means modifying the shock, possible on Bilsteins and Konis, probably not doable on KYB and other standard replacement shock. Sherwood |
r_towle |
Mar 5 2016, 11:30 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I believe they are required for any strut insert to prevent bottoming out the strut itself and keep it from getting internal damage.
Sport struts, koni and bilstiens make them, have shorter internals so you can run a lower setup and not need the same height bump stop, but should use a shorter one. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:18 AM |
