opening the case, of the engine block |
ben1440 |
Mar 25 2005, 09:40 PM
Member Group: Members Posts: 171 Joined: 1-March 05 From: Santa Rosa Ca Member No.: 3,688 |
I have removed just about everything i can possible take off the block except for what is inside it. I am assuming with all bolts and everything taken off i would basically be prying the block apart but my knowledge is limited. Am i right in trying to pull it apart?
Mueller |
Mar 25 2005, 09:42 PM
if all the bolts are removed, then yes, pull it apart
you can do a search here, someone listed the all of the bolts in case you cannot get it apart........ |
SirAndy |
Mar 25 2005, 11:45 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
yes, you're right ... if i recall correct, there's one bolt somewhere people always overlook. if it doesn't come apart easy, you might want to double-check ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Mark Henry |
Mar 26 2005, 07:40 AM
Yep there is a couple of hidden bolts/nuts. There's one bolt just below the 3/4 main through bolt that sits way in the case. Newbie's always seem to miss that one.
If it won't come apart you've missed a bolt bolts or nut. BTW do not use a prybar of BFH (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) you'll just wreck the case. |
Lo-Fi Version | Time is now: 8th June 2024 - 05:50 PM |
