Trailing Arm Reinstall Question |
Amphicar770 |
Mar 30 2016, 02:32 PM
Senior Member Group: Members Posts: 1,195 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Going to put the rebuilt trailing arms back in.
1) Should I put axles in arms first or after the arms are on car. 2) When tightening up the bolts on the new bushings. Should car be fully loaded (i.e sitting on its wheels)? Thanks, Mike |
6freak |
Mar 30 2016, 03:18 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
Going to put the rebuilt trailing arms back in. 1) Should I put axles in arms first or after the arms are on car. 2) When tightening up the bolts on the new bushings. Should car be fully loaded (i.e sitting on its wheels)? Thanks, Mike seeings how none of the really smart guys have chimed in ill give you my 2 cents ?1 yes the stub axles do,not the trans axles ?2 I just put mine togather in the air and tighted everything,its pretty tuff getting in there with car on the ground.. MikeC good luck |
ThePaintedMan |
Mar 30 2016, 04:10 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
If you leave/take the starter off it makes putting in the drivers side axle much easier.
ClayPerrine |
Mar 30 2016, 04:13 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I just replaced trailing arms on Betty's car. I left the axles on the car, and inserted them into the trailing arm when I put them on.
So I would put the axle on first. |
LowBridge |
Mar 31 2016, 08:22 AM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:34 AM |
