| Mikey914 |
Apr 11 2016, 01:35 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
We started this project literally years ago. The thought process was to go to a neoprene to improve the seal, unfortunately even the softest neoprene was holding the trunk up and not allowing it to sit properly.
Initially we planned to glue the corners as others have done. This is great until you get to the seam at the top of the trunk. It actually has to step down. So we put this on hold until I could re-evaluate it. The only way the upper section can be made correctly is molded corners. So we bit the bullet and made the 2 molds (yes can't be the same one as they are not 90s). Making as a molded and bonded product is the only way to go. Factory had it right to start with. We did however make our corners from a softer material to allow it to close a little easier. You may not even notice but we did want to make the best product we could. Attached thumbnail(s) |
| mark04usa |
Apr 11 2016, 01:49 PM
'70 1.7 Tangerine ![]() ![]() Group: Members Posts: 361 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region
Mark,
How sturdy are the corners? Replacements for these seals often break at the corners, especially after stretching because they are made too short to begin with. Hope yours are better! (IMG:style_emoticons/default/smile.gif) |
| aharder |
Apr 11 2016, 01:58 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,954 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region
I'm in for one (IMG:style_emoticons/default/biggrin.gif)
| mepstein |
Apr 11 2016, 02:02 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I guess I need 4
| JP3 |
Apr 11 2016, 02:54 PM
Jerry ![]() ![]() Group: Members Posts: 61 Joined: 6-August 15 From: New Lenox, IL Member No.: 19,035 Region Association: None |
Put me down for one.
| Mr.Nobody |
Apr 11 2016, 04:04 PM
Member ![]() ![]() Group: Members Posts: 133 Joined: 24-March 15 From: San Diego, Ca Member No.: 18,557 Region Association: Southern California
In for one.
| bandjoey |
Apr 11 2016, 04:25 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Seal
2 Rubber license plate bodies ( no innards) full hood clear vinyl paint protector film (IMG:style_emoticons/default/biggrin.gif) |
| dlee6204 |
Apr 11 2016, 04:30 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
Awesome. Definitely in for one.
| t collins |
Apr 11 2016, 05:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
One for me please (IMG:style_emoticons/default/bye1.gif)
| Mblizzard |
Apr 11 2016, 05:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Mark,
You know that my car is pretty much 914 Rubber in every possible location. While I have your current seal, this one looks like an improvement so count me in. |
| cpavlenko |
Apr 11 2016, 05:28 PM
Member ![]() ![]() Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
i like it...when can i get
| edrotol |
Apr 11 2016, 05:33 PM
edrotol ![]() ![]() Group: Members Posts: 210 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States |
We started this project literally years ago. The thought process was to go to a neoprene to improve the seal, unfortunately even the softest neoprene was holding the trunk up and not allowing it to sit properly. Initially we planned to glue the corners as others have done. This is great until you get to the seam at the top of the trunk. It actually has to step down. So we put this on hold until I could re-evaluate it. The only way the upper section can be made correctly is molded corners. So we bit the bullet and made the 2 molds (yes can't be the same one as they are not 90s). Making as a molded and bonded product is the only way to go. Factory had it right to start with. We did however make our corners from a softer material to allow it to close a little easier. You may not even notice but we did want to make the best product we could. in for one. thanks |
| jacquot |
Apr 11 2016, 05:41 PM
Member ![]() ![]() Group: Members Posts: 59 Joined: 12-March 15 From: Huntington Beach / Paris Member No.: 18,512 Region Association: Southern California |
I'm in for one, thanks.
| ConeDodger |
Apr 11 2016, 05:46 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,396 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
One for me...
| mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,729 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Mark you have all these awesome group buys waay before I am ready for them.. Still more welding to do before painting and time for seals.. Great work.
| Mikey914 |
Apr 11 2016, 07:07 PM
Mark, How sturdy are the corners? Replacements for these seals often break at the corners, especially after stretching because they are made too short to begin with. Hope yours are better! (IMG:style_emoticons/default/smile.gif) The upper corners are actually a single part molded. Then thermally bonded - NOT glued. These are a much better fit than the other cheaper seal on the market. You also have the knowledge it's a genuine 914rubber part! You will not have the variation on these that others have with theirs, ours is exactly the same dims as OEM. |
| SA-914 |
Apr 11 2016, 07:31 PM
Member ![]() ![]() Group: Members Posts: 129 Joined: 30-June 14 From: San Antonio,tx Member No.: 17,566 Region Association: Southwest Region |
I'll take one.
| 76-914 |
Apr 11 2016, 07:43 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Great (IMG:style_emoticons/default/sheeplove.gif) news, Mark. Definitely 2 please. (IMG:style_emoticons/default/beerchug.gif)
| tygaboy |
Apr 11 2016, 08:23 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,803 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
That seals the deal for me. (IMG:style_emoticons/default/lol-2.gif)
I'll need 2. |
| michael7810 |
Apr 11 2016, 08:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region
One for me please.
Lo-Fi Version | Time is now: 2nd April 2026 - 12:13 PM |
