front strut installation |
fduval |
Apr 14 2016, 10:04 AM
Newbie Group: Members Posts: 41 Joined: 2-January 13 From: quebec Member No.: 15,331 Region Association: Canada |
I have these Boge front struts ( the portion that attaches to the ball joint is threaded )
the lock pin does not work with this kind of strut. What do you guys use to secure the lower portion of the strut to the ball joint ? Is there a special kind of bolt ? thanks Francois |
PancakePorsche |
Apr 15 2016, 01:43 AM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
There is two types of of struts. One uses thru bolt and nut. ball joint has semi circle or moon cutout on ball joint shaft. The second (later) style uses tapered wedge bolt and ball joint has V shaped cutout.
fduval |
Apr 15 2016, 04:42 AM
There is two types of of struts. One uses thru bolt and nut. ball joint has semi circle or moon cutout on ball joint shaft. The second (later) style uses tapered wedge bolt and ball joint has V shaped cutout. Thanks, do you know where I can source the bolt and nut to secure the strut to the ball joint? Francois |
Jeffs9146 |
Apr 15 2016, 07:31 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
You need the proper ball joint for the struts that you have! Early or late.
Lo-Fi Version | Time is now: 11th June 2024 - 07:47 AM |
