Fuel Filters, How many? |
Allan |
Mar 30 2005, 03:22 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I have a strainer in the tank to keep the twigs, leaves, big rust chunks, and anything I've accidentally dropped into the tank out of the motor. Then there is the big filter under the tank going to the pump. Do I need one in the engine bay as well?
Aaron Cox |
Mar 30 2005, 03:24 PM
i use 2...
1 before the pump (save the pump from debris) 1 before the carbs (they are expensive.....preventative measures) |
machina |
Mar 30 2005, 03:25 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
i have an 8 micron at the tank and a 1 micron back at the motor. Probably overkill.
mihai914 |
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
No, those are the regular fuel filters on your car, if you want an extra one for security it's up to you but it would be pretty much useless.
Allan |
Mar 30 2005, 03:44 PM
I'll probably put one in just for the hell of it. The PO had one on the return line back to the tank. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
Lo-Fi Version | Time is now: 4th June 2024 - 08:42 AM |
