914 |
Senior Member ![]() ![]() Group: Members Posts: 460 Joined: 26-December 02 Member No.: 19 Region Association: Southern California ![]() ![]() |
Any Ideas as what is the best battery for a 1971 914-4?
Thanks,914 |
Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,219 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
A lot of people use the Optima batteries. No worries about acid damage to the hell hole area.
malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
A lot of people use the Optima batteries. No worries about acid damage to the hell hole area. IIRC I got a RED TOP R34. Worth the extra $... Amazon probably has the best price, especially if you have access to Prime. I also remember using the shipping spacer so the factory hold down clamp will hold it down. I is just a red tray the battery clips to the bottom of the battery and that moves it enough for the clamp to catch it. ![]() |
1TRICK6 |
Newbie ![]() Group: Members Posts: 45 Joined: 13-July 11 From: Southern California Member No.: 13,313 Region Association: Southern California ![]() |
Bosch 96R battery fits perfect.
Check PepBoys, usually on sale around $90. |
malcolm2 |
Something else I really like are my connectors. I got a low profile type. That keeps the rain tray from hitting the battery. It pinches the battery stud with an allen bolt. You can't see it on this picture, it is on the back. The stud is under the logo. And you get 3 large accessory connectors that work with a Phillips screw driver. Also great with FI cars that have 3 or 4 hots to mount.
I now just hate the standard connectors. The pinch nut is too close to the battery top and the wrench always slips off, or you don't have room and you spark up the world messing with it. This one is perfect. ![]() |
914 |
Thanks everyone for the reply's.I got the Bosch 96R..
914 |
era vulgaris |
J is for Genius ![]() ![]() ![]() Group: Members Posts: 983 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States ![]() |
A lot of people use the Optima batteries. No worries about acid damage to the hell hole area. IIRC I got a RED TOP R34. Worth the extra $... Amazon probably has the best price, especially if you have access to Prime. I also remember using the shipping spacer so the factory hold down clamp will hold it down. I is just a red tray the battery clips to the bottom of the battery and that moves it enough for the clamp to catch it. If I think about it, I'll get a photo of mine this afternoon and edit this. ![]() (IMG:style_emoticons/default/agree.gif) I got mine from amazon. Cheapest price I could find. No more worries about battery acid eating away my car! Attached thumbnail(s) ![]() |
913B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 863 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None ![]() |
Thanks everyone for the reply's.I got the Bosch 96R.. 914 neverheard of a bosch battery,, if you find the time maybe attach an installed pic by request (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
struckn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region ![]() |
If it's a Vented Battery, such as I have, buy a Battery Mat that will help control the vented Battery Acid that excapes. Cut the mat to size and put it under the Battery on the tray, and also cut a peace to go Vertically behind the battery. Replace it every couple years, it will nuetralize the acid.
914 |
Amphicar770 |
Here is the Bosch battery..Again Thanks everyone for the replys.. 914 I thought you wanted the best battery for your 914? (IMG:style_emoticons/default/biggrin.gif) Nothing wrong with the Bosch but, as with any lead acid battery, make sure you have an acid mat underneath. |
914 |
Always used a mat on my Four and Six..
914 |
championgt1 |
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,681 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest ![]() |
Thanks everyone for the reply's.I got the Bosch 96R.. 914 neverheard of a bosch battery,, if you find the time maybe attach an installed pic by request (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) I have one as well. After returning 3 Optimas in a year and a half I switched to this. ![]() |
JFG |
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None ![]() |
Any chance you can post the dimendions of the bosch battery?
dlkawashima |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California ![]() |
1stworks |
Member ![]() ![]() Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None ![]() |
Here's what I did.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1464008386.1.jpg) |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,400 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
When it comes time for a battery, it is going to be a sealed battery for sure. No more leaking acid worries, regardless of a battery pad/liner.
dlkawashima |
When it comes time for a battery, it is going to be a sealed battery for sure. No more leaking acid worries, regardless of a battery pad/liner. Online battery purchases are 25% off at Pep Boys right now. But be careful about the end date because there appears to be some confusion on their own site about when the sale ends. One link says the end of May while others say the end of June. Might want to call a store to verify. Here is what gets pulled up when doing a search for Bosch AGM batteries: https://www.pepboys.com/search/?term=bosch+agm+battery Example ... ![]() |
fslick |
Newbie ![]() Group: Members Posts: 14 Joined: 8-April 12 From: Pittsburgh, PA, USA Member No.: 14,347 Region Association: None ![]() |
dlkawashima, do you run a size 34? Would really like a Bosch AGM but worried a size 34 is too/long tall. Looks like Bosch doesn't make an AGM in 96R (or original size 42). Thanks! (IMG:style_emoticons/default/smile.gif)
arne |
Serial Rescuer of old vehicles... ![]() ![]() ![]() Group: Members Posts: 780 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None ![]() |
I put a Miata U1R AGM in mine. Smaller, lighter, cheaper than most AGM. You do need to build your own hold down for it, but for the price it's hard to beat. I paid $112.50 at Batteries Plus.
Lo-Fi Version | Time is now: 31st July 2025 - 03:42 AM |
