Targa side seal mounting |
BCinSC |
Jun 19 2003, 07:28 AM
Nothing but Trouble Group: Members Posts: 138 Joined: 8-June 03 From: Wakefield, MA Member No.: 800 Region Association: North East States |
(IMG:style_emoticons/default/headbang.gif) Tried both ways and always leak. When mounted way I think is correct, don't match up to windshield or side seals. Argh.
tod914 |
Jun 19 2003, 07:54 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
well firstly, make sure your putting the correct one on each side. there is a left and a right. The numbers are on your seals so you can match them up. The slide into the channel - might require alittle hand lotion on them to make them go in easier. You can also adjust your windows to fill up the gap. for that you need to remove your door panels.
827 10 = left 828 10 = right I assume its the roll ball vertical side seal your talking about. The angle / shape goes at the top |
Lo-Fi Version | Time is now: 13th June 2024 - 11:09 AM |
