> Electric AC compressor
rgalla9146
post May 18 2016, 05:19 PM
Anyone here have experience with self contained 12V AC compressor ?
Mounts remote from engine, driven by electric motor.
Seems it might be a way to have AC on a 6 conversion.
Jegs sells them in two capacities.
Pretty spendy.
Replies(1 - 19)
whitetwinturbo
post May 18 2016, 06:12 PM
bandjoey
post May 18 2016, 06:40 PM
bandjoey
Electric AV compressors in cars use up to 230v. (IMG:style_emoticons/default/sad.gif) If you see a 12v one let us know. Several Ac threads where this has been talked about.
http://www.revoltev.com/2013/08/02/the-12v...oling-solution/
rgalla9146
post May 18 2016, 07:53 PM
QUOTE(bandjoey @ May 18 2016, 08:40 PM) *
As mentioned, sold by Jegs part # 51810
9 -30 volts, 31 amps, 3753 btu
Available in two versions for small or larger cars. (specs listed are for the smaller
unit)
Was $1199 ...... now $749.99
Not doable with a 160 amp 911 alternator ?
Has anyone here seen one installed on anything ?
Gunn1
post May 18 2016, 08:00 PM
[quote name='rgalla9146' date='May 18 2016, 08:53 PM' post='2346865']
[quote name='bandjoey' post='2346821' date='May 18 2016, 08:40 PM']
[/quote]
unit)
Prob need a higher output alternator or maybe a dedicated alternator that would run just the AC, would probably still be easier than installing an old school set up
barrym
post May 18 2016, 08:04 PM
A few of my lotus friends have used this solution with engine swaps where it's hard to mount a compressor in limited space.
Yes, you need a correctly sized alternator, but the platform works just as advertised, but I wouldn't be looking at this for any cabin size larger than an Elise / 914
Gunn1
post May 18 2016, 08:19 PM
QUOTE(barrym @ May 18 2016, 09:04 PM) *
I got it ....fill the Frunck with ice cubes and redirect the fresh air intake into the Frunck.
Make sure to set up some sort of drain though.
r_towle
post May 18 2016, 09:55 PM
Custom Member
Boating world has made some great progress in sure small heat/AC units running off 12 Vdc.
Those are sized to service large cabins maybe ten time the size of a 914 cabin.
From what I have read, these are just how it's done now.
Taking that design and scaling it down...I don't see any reason why it would not work fine....just need to see the power requirements.
Heating and cooling with electricity is not magic, it takes power to make heat and cooling...
boxsterfan
post May 18 2016, 10:20 PM
914's are kewl
I think McMark fitted a 130A GM alternator on a type IV motor with or without built-in voltage regulator. There is also a 230A GM alternator that can be used just as the 130A one.
Gunn1
post May 19 2016, 12:17 PM
QUOTE(r_towle @ May 18 2016, 10:55 PM) *
That being said, when you increase the output of the alternator don't you increase the power consumed to spin it?
I would be curious to know which set up was more efficient.
In other words the power needed or used to produce the same BTU's
jd74914
post May 19 2016, 01:02 PM
Its alive
QUOTE(rgalla9146 @ May 18 2016, 08:53 PM) *
unit)
I don't see why you couldn't use one with the 160A alternator; I would assume that your car draws nothing near that load (assuming you're not rocking a xrazy stereo, etc.).
Dave_Darling
post May 19 2016, 01:49 PM
914 Idiot
QUOTE(OU812 @ May 19 2016, 11:17 AM) *
Converting energy from one form to another is never 100% efficient. The more conversions you have, the worse the efficiency is.
With one setup, you have mechanical energy -> thermal energy.
With the other, you have mechanical energy -> electrical energy -> mechanical energy -> thermal energy.
The first one needs to be hellaciously inefficient, and the latter three all very efficient, for the second setup to be more efficient than the first.
Given the same type of mechanical compressor at the end, the electric-driven one will never be as efficient as the straight mechanical one.
--DD
jeffdon
post May 19 2016, 03:14 PM
QUOTE(OU812 @ May 18 2016, 07:19 PM) *
I believe Eliot did an ice based AC system using an ice chest, coil in the ice, water in the coil, all pumped through a heater core with a fan. I seem to recall him saying it worked pretty well even in the hot summers he gets. Just need to replenish the ice once in a while. Bet with some of the new super ice boxes, like Yeti, and with a brine/ice solution, it would be even better.
porschetub
post May 19 2016, 06:36 PM
230amp altenator holy...drive that ,turn the cooling fan and turn the back wheels,might need a BIG Raby motor for that system (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) .
Not to mention a suitable battery and associated wiring to power the beast.
I lived in Australia pretty hot there , I wound down the window (IMG:style_emoticons/default/dry.gif)
Steve
post Aug 5 2016, 12:28 AM
I am starting to see this one pop up in various threads.
Benling DM18A7
From Chine it lists for $300.00 on eBay they want $899 for it.
It looks pretty promising, but no luck finding one.
http://m.made-in-china.com/product/Dm18A7-...-761066265.html
https://m.alibaba.com/product/60112520554/1...sor-DM18A7.html
jim_hoyland
post Aug 5 2016, 05:49 PM
Get that VIN ?
Steve: what's your alternator put out ? How many amps will the electric compressor require ?
Steve
post Aug 5 2016, 05:57 PM
QUOTE(jim_hoyland @ Aug 5 2016, 04:49 PM) *
I have a stock 98 amp Alternator. The electric compressor can run at 40, 60 or 90 amp. Even the 40 amp setting should be able to cool our tiny compartment
Elliot Cannon
post Aug 5 2016, 08:22 PM
Group: Retired Members
QUOTE(jeffdon @ May 19 2016, 02:14 PM) *
I worked at it for awhile. Kinda gave up on it. These work well. I would guess it would last about 2 hours or so before you have to stop for more ice. In an airplane you might only need it for a short while anyway. It can get pretty cool at altitude. http://portable-aircraft-air-conditioners-...nstruction.com/
Series9
post Aug 5 2016, 08:29 PM
Lesbians taste like chicken.
The answer is: NO.
I don't feel like explaining it right now, but forget about it.
Rand
post Aug 5 2016, 09:17 PM
Cross Member
It would work about as well as a 12v electric heater. (IMG:style_emoticons/default/wink.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 02:54 PM
