CV Joints, Curil K |
srreality |
May 21 2016, 11:18 AM
Member Group: Members Posts: 73 Joined: 14-July 15 From: Colorado Member No.: 18,957 Region Association: None |
Beginner's dumb question #56: The Porsche factory manual says to "Glue plate spring with specified grease to joint, with hollow end facing the joint. If the cap has been removed from the joint, seal again with compound Curil K"
2 questions: Is there an equivalent to Curil K available at any auto parts store? Where does the "glue" go on the plate spring/spring retainer to joint go? I bought new CV boots with cap already attached, so I assume sealant goes around joint itself before slipping it into the boot/cap, wiping off the excess? Thanks, |
914Sixer |
May 21 2016, 12:24 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
NO glue needed. Just put them on and use them. Compression will keep them in place.
Lo-Fi Version | Time is now: 10th June 2024 - 01:59 AM |
