spark plug reccos, 12mm options |
iankarr |
May 25 2016, 10:49 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
My 2056 has heads threaded for 12mm plugs. The PO was running NGK DR8ES-L. That's a 19mm thread reach. I was thinking of running a hotter plug, but can't seem to find a 6 rating in 12mm. And not sure if the 19mm depth is advisable. Would also love to find a plug with integrated terminal tips...as these are threaded but don't come with the terminal nut. How much could NGK really be saving by not including those! Thoughts or suggestions? Thanks! |
era vulgaris |
May 25 2016, 12:15 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
I'm using the NGK DP8EA-9 in my 2270. They also don't come with the screw on tips though, so I borrowed them from another set of NGK plugs that I had that had them.
MarkV |
May 25 2016, 01:02 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I am running are 12mm NGK DR7EIX Irridium. I think they came with the screw on tips.
Lo-Fi Version | Time is now: 7th June 2024 - 12:06 PM |
