rupert14 |
Member ![]() ![]() Group: Members Posts: 76 Joined: 25-December 04 From: Prescott AZ Member No.: 3,339 Region Association: Southwest Region ![]() |
I have searched for cis and fuel injection and I have read in several forums that the CIS systems are the best once setup. I found this CIS system on ebay and was wondering if it would be a good start. IF not, what do you recomend? Would the megasquirt be good for a turbo application? I ordered the Turbomania book and it should be here any day. Also, does anyone make a independent system that runs the fifth injector and is controlled by boost pressure and O2 sensor? I am debating going big block but I would really like to get 5-6lbs boost on my 2.0 and keep this one running on porsche ponies.
bob http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMEWA%3AIT |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
the CIS should be the most reliable and simple...with low to moderate boost levels....
the Megasquirt would be perfect if you decided to crank up the boost and needed the extra fine tuning that one can achieve with EFI..... most of the aux. fuel injector systems cost about $300, so you might as well just do the complete FI swap....besides, getting the 5th injector to spray evenly might take more work than it's worth on a /4 motor...it's been done on the /6's with success, but a company did all the work (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
rhaas |
Member ![]() ![]() Group: Members Posts: 63 Joined: 16-January 03 From: Bay Saint Louis, MS Member No.: 155 ![]() |
I got a cis system out of a turbo volvo. I got the entire system from a u pull it for $50. I got all the thing hooked up to it including the turbo and the fuel pump. now only to find time to work on it.
Lo-Fi Version | Time is now: 14th June 2024 - 02:33 PM |
