Throttle cable routing, Is this where it goes? |
jack20 |
May 28 2016, 10:36 AM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
I finally installed the engine yesterday. Now I'm doing the hook-ups. I shoved the throttle cable up into the engine compartment through the only available hole in the tin. It doesn't look right. I might have had an old dried out grommet there before but I just can't remember.
Is this where the cable is supposed to go? I looked on 914 Rubber for a grommet and couldn't find one. Here is a picture. Unfortunately i don't have a good enough "before" picture to help out. Thanks in advance. Jack |
ejm |
May 28 2016, 11:03 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
That is the factory hole for the throttle cable. The grommet is nothing special, you should be able to find something suitable at a hardware store.
jack20 |
May 28 2016, 11:43 AM
Lo-Fi Version | Time is now: 29th May 2024 - 01:57 AM |
