front lights, best way to remove to put new rubber in? |
7391420 |
Apr 4 2005, 02:45 PM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
What's the best way to remove the front side turn signals, and front indicator assemblys?
-I'm guessing remove the front wheels and look for bolts? I'm putting new gaskets on both and cant get the gasket on without removing the assemblys...PIA -adam |
rhodyguy |
Apr 4 2005, 03:45 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
turn the wheels full lock one way or the other. looking at the backside of the turn signal you will see a u shaped piece of metal that acts as a clamp. it is held on with one nut. loosen it. if you are careful you may not even disturb the wiring (but make note of what goes where first), you only need loosen the nut enough to move the housing outward to get the seal under it. turn wheel, repeat.
k |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:42 PM |
