WTB: Trailing Arm Outer Pivot Mounts L&R. |
tach |
May 31 2016, 06:10 AM
Member Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest |
I need the left and right outer trailing arm pivot mounts. This is a part bolted to the trailing arm and support the outer side of the trailing arm to the suspension console. See the picture.
I also need one left & right L-Shaped 3 hole washer type bracket that fit between the bolts and the trailing arm pivot mounts. |
bdstone914 |
May 31 2016, 06:52 AM
bdstone914 Group: Members Posts: 4,524 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have all of those parts as a set. Powder coated brackets, replated hardware and new Schnoor washers for the bolts.
Can put together more set if anyone else is interested. Bruce Attached thumbnail(s) |
tach |
May 31 2016, 06:58 AM
bdstone914 |
May 31 2016, 07:04 AM
So you want the L plates and used brackets? The Schnoor washers are a one use washer and need to be replaced.
tach |
May 31 2016, 11:12 AM
bdstone914 |
May 31 2016, 12:50 PM
Used plates and used brackets. No washers or bolts. Zip 55082
Thank you [/quote] like this? Attached thumbnail(s) |
tach |
May 31 2016, 01:08 PM
[quote name='bdstone914' date='May 31 2016, 01:50 PM' post='2352730']
Used plates and used brackets. No washers or bolts. Zip 55082 Thank you [/quote] like this? [/quote]yYes, that's what I need. How much $. |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:17 AM |
