flasher relay, where is it? |
Schnell944 |
Jun 19 2003, 07:12 PM
Member Group: Members Posts: 121 Joined: 4-January 03 Member No.: 86 |
got a new relay and looked at the Haynes manual and couldnt find where this thing goes....doesnt look like its shaped for the relay spots in the fuse box, plus those are for other things. also....i how do u get to the hazard light switch behind the pull knob. haynes says just to take it out, but it doest fit through the little hole. thanks!
Schnell944 |
Jun 19 2003, 08:04 PM
no one really knows?
ChrisReale |
Jun 19 2003, 08:11 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Unscrew the knob, and it should come out the back. Cant help with the flasher relay. Did you unscrew the fuse block, there are a few relays on top of it..
Lawrence |
Jun 19 2003, 08:20 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
IIRC, the relay is under the dash.
I would go look, but it's raining like hell. |
MarkV |
Jun 19 2003, 08:31 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Take the 2 screws out of the fuse panel, it drops down & the relay is above it. Mine is just laying up on top of the fuse panel.
Schnell944 |
ya, i'd go look now too, but its dark AND raining
iansale |
Jun 19 2003, 08:58 PM
Newbie Group: Members Posts: 21 Joined: 12-June 03 From: Havertown, PA Member No.: 810 |
It might be the square relay in this picture. The reason I'm not certain is that, on my car, there is a second larger "square" relay that is just sort of resting on the lower dash shelf. I think that the one hanging loose is for the wiper intervals.
MarkV |
Jun 19 2003, 09:13 PM
There it is.
Attached image(s) |
SirAndy |
Jun 20 2003, 11:01 AM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(iansale @ Jun 19 2003, 07:58 PM) I think that the one hanging loose is for the wiper intervals. nope, wiper interval is in the front trunk ... flasher relay is behind the dash, above the fuse panel. there's actually a little hole in the bottom of the dash where the relay is supposed to be mounted, but most of them just just dangle there ... Andy |
Dave_Darling |
Jun 20 2003, 05:08 PM
914 Idiot Group: Members Posts: 14,990 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There are two square relays. One is the high/low beam relay, the other is the flasher.
The hazard switch is removed in the same way as the other dash-mounted switches--unscrew the knob, then find a way to unscrew the round metal plate that acts as a nut to hold the switch to the dash face. I have been able to use a small flat-head screwdriver to push the "escutcheon" (as the manual calls it) to loosen it. When it's loose, you can use finger pressure to turn it. Unplug your battery (-) terminal first, though. The switch will fall down inside the dash and one of the "hot" wires might short out on something... --DD |
SirAndy |
Jun 21 2003, 12:18 PM
QUOTE(Dave_Darling @ Jun 20 2003, 04:08 PM) I have been able to use a small flat-head screwdriver to push the "escutcheon" (as the manual calls it) to loosen it. When it's loose, you can use finger pressure to turn it. i have been using a "Quarter" (IMG:style_emoticons/default/cool.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:54 PM |
