Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,219 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
Hi All,
Last night I unboxed and installed the precision shift adjuster from Tangerine Racing. This definitely lives up to the high standard we have come to expect from Chris. I found myself looking at it for a while just to admire the engineering and fabrication work that went into this. The level of skill and craftsmanship is truly impressive. Installation went pretty smooth. As someone else mentioned, a 15mm box end wrench will give you needed leverage to slip the gear onto the shift rod and make adjustments if needed. Once in I initially had only two gears. Gave the magic adjuster a few turns with an allen wrench. That got me closer and helped me understand how it works. From there it was easy to fine tune to just the right spot. The hardest part of adjusting shift linkage if you have this is removing the center console. I also installed Chris' shift wall bushing which is another piece of engineering artwork. |
Lo-Fi Version | Time is now: 4th July 2025 - 08:09 PM |
