JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,974 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I hear they are done to eliminate valve adjustments on a T4 motor.
Other pros/cons? Is there machining required or are they drop in and thus reversible? |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,964 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
You don't do it on a 914 motor since you want it to rev.
MichaelB |
Newbie ![]() Group: Members Posts: 23 Joined: 24-June 12 From: Wisconsin Member No.: 14,598 Region Association: None ![]() |
I am not the expert opinion you are looking for but on the engine I rebuilt, started with a GA case (supposedly "unmolested") motor that had hydraulic lifters and dished pistons (which with the 914 2.0 heads must have dropped the compression a pretty good bit). I replaced both the pistons and added a 9590 kit. The case did have the secondary oil pressure relief valve (under cylinder 1) and it had copper plug behind the screw/plug to block it off. I believe most bus motors with hydraulic lifters had this plugged from the factory. As we know the bores for these relief valves are often poor/irregular or worn (and leak or stick). If you have a secondary valve, addressing it might be a consideration in keeping pressure up for the hydraulic lifters.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
I hear they are done to eliminate valve adjustments on a T4 motor. Other pros/cons? Is there machining required or are they drop in and thus reversible? You need a different cam, pushrods for it to work. Not very sporty on the one 914 that had em I worked on. Killed the rev's. |
larryM |
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California ![]() ![]() |
https://www.google.com/search?q=914+hydraul...-8&oe=utf-8
your problem will be getting it to work with D-jet if that is your plan i tried it in a 2.0 many yrs ago (circa 1990-93) with the intent to avoid continual valve adjusting - WebCam 94 was the number back then - new numbers & several grinds now - find all the needed parts on this site www.webcamshafts.com/mobile/automobile/porsche/porsche_914_8v.html - the hydraulic engine vacuum profile is entirely different & it requires a LOT of tuning & fiddling to get it running anywhere near right if not running D-jet you will like the result - the VW buses ran 'em with L-jet & you can likely find a lot of help on the Samba in that regard fwiw i finally gave up trying to tune it & went back to a Web Cam 73 with D-jet and Ed Mazula 4mm overbore TB - it was a mid-range screamer! there are old threads on this 'way back - pre-914World, but Samba is your best source . yes it is reversible! - i did it - the adventure cost me a LOT OF TIME - at 35 hrs flat rate to teardown & reassemble, one must think hard about that prospect - that's X2 since it meant doing it twice |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,200 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Ramp rates on the cam have to be set up for the hydro lifters, so you can't use a stock cam.
The valves still have to be adjusted, but if you drive the car regularly you won't have to do it as often as with solid lifters. There is some argument about exactly how much pre-load to use on the valve adjusters when you have hydro lifters. Generally the hydro lifter setups will impact high-RPM power. Supposedly, if you do a solid-lifter adjustment on a hydro motor, you can kill it. I'm not sure I buy it, but someone who has dealt with more motors than I have insisted that had happened to him. --DD |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Very annoying when the lifters have to pump up after longish durations of not driving the car. It can be noisy.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
It works, not optimum but it can be a dropped in thing.
Had a buddy do a 2.6 liter with them....he loved the lack of valve adjustment. Rich |
Lo-Fi Version | Time is now: 12th July 2025 - 11:03 AM |
