mmascari |
Member ![]() ![]() Group: Members Posts: 322 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None ![]() |
Hi everyone, I am ready to install my seat belts and need some help figuring out how to install. I included a picture. Where does the part I am pointing to go in relation to the belt? Thanks in advance. If someone has a picture of one installed that would be great.
Attached image(s) ![]() |
zambezi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States ![]() |
I believe it mounts with and behind the retract-er assembly. The round loop portion is where the bolt passes through using the same bolt as the retract-er. They simply guide the belt into the retract-er so it doesn't get twisted as it winds back up.
mmascari |
I believe it mounts with and behind the retract-er assembly. The round loop portion is where the bolt passes through using the same bolt as the retract-er. They simply guide the belt into the retract-er so it doesn't get twisted as it winds back up. Thanks for the response....after looking at it for a few minutes that is what I thought but wasn't 100% sure. |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
The pointed thing on the reel part goes through the round loop on the chrome part.
Then, you bolt it to the firewall. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
To add to the above, the reason you have the metal loop is that the belt reel only works if the belt is pulled straight down. It won't work if it is pulled in any other direction.
The metal loop makes sure that the belt always pulls correctly on the reel no matter where the rest of the belt is pointed at. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 6th July 2025 - 12:09 PM |
