pgollender |
Member ![]() ![]() Group: Members Posts: 201 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California ![]() |
All I really want for father's day is to spend a little time with my dad and to start my new motor. (IMG:style_emoticons/default/hissyfit.gif)
On the run stand: ![]() Everything primed except oil. and the starter won't spin: Here are the brushes: ![]() Here is the armature/communicator: ![]() Here is the casing/Bosch part ID: ![]() When the brushes get this worn, will it not spin the armature ? Can you just order the brush plate assembly ? |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Does it spin if you apply voltage directly to the motor windings?
Does the solenoid kick it out? If the solenoid kicks out does it apply voltage to the starter windings? |
pgollender |
Does it spin if you apply voltage directly to the motor windings? Does the solenoid kick it out? If the solenoid kicks out does it apply voltage to the starter windings? Applying voltage on the bench to the solenoid kicks the armature out. I didn't think to bypass the solenoid and apply voltage directly to the motor windings. Or to see if I have no current past the solenoid. So If motor runs when directly connected, then the Solenoid to motor connection is bad. I will try that next. Thanks !!! |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Braided wire you can see might be broken
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I have a starter you can use for testing, not sure where it is exactly (which box/tub in the shed).
Where in Sac are you? I work in Elk Grove & live in Carmichael. There used to be a starter/alternator shop down by Sac City college, not sure if they are still there. Jim |
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,492 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
All I really want for father's day is to spend a little time with my dad and to start my new motor. (IMG:style_emoticons/default/hissyfit.gif) When the brushes get this worn, will it not spin the armature ? Can you just order the brush plate assembly ? I looked hard for the brush plate assembly. You can find them for many starters, but I failed to find one for the Bosch starter. |
pgollender |
I have a starter you can use for testing, not sure where it is exactly (which box/tub in the shed). Where in Sac are you? I work in Elk Grove & live in Carmichael. There used to be a starter/alternator shop down by Sac City college, not sure if they are still there. Jim Cool Jim, Thanks. Do you remember the approximate street that shop was on ? Another 914 member in Loomis I think has offered the same thing. I live in West Roseville near HP. Let me see what he says. I have Tuesday off so if your schedule is good maybe we can meet up. Paul G |
jcd914 |
I have a starter you can use for testing, not sure where it is exactly (which box/tub in the shed). Where in Sac are you? I work in Elk Grove & live in Carmichael. There used to be a starter/alternator shop down by Sac City college, not sure if they are still there. Jim Cool Jim, Thanks. Do you remember the approximate street that shop was on ? Another 914 member in Loomis I think has offered the same thing. I live in West Roseville near HP. Let me see what he says. I have Tuesday off so if your schedule is good maybe we can meet up. Paul G It was a side street off Freeport blvd, pretty sure it was accross from the high school near Sac City . I will be in Roseville on Tuesday near Kiaser, don't know when yet. I'll PM you my phone number. Jim |
raw1298 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California ![]() |
I am in Rocklin and have a starter in a box. You are welcome to try it.
pgollender |
Does it spin if you apply voltage directly to the motor windings? Does the solenoid kick it out? If the solenoid kicks out does it apply voltage to the starter windings? Power to the selenoid kicks out the armature, but doesn't spin the motor Power to directly to the motor spins the motor, but no armature movement... So does that mean the selenoid transfer plate is bad ? The selenoid shouldn't get hot should it ? |
Lo-Fi Version | Time is now: 31st July 2025 - 03:39 PM |
