1.8 CHT sensor, Cant find any for sale |
djway |
Jul 12 2016, 04:49 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
I have a bad head temperature sensor on my 1974 1.8 914. I called Pelican Parts and they say they are not available. My car is just dumping fuel and I cant drive it until I get a new one.
Where can I find them? Thanks Dwayne |
Dave_Darling |
Jul 12 2016, 04:55 PM
The D-jet ones should work, at least to some extent.
--DD |
djway |
Jul 12 2016, 05:04 PM
Big Len |
Jul 12 2016, 05:26 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
TheCabinetmaker |
Jul 12 2016, 05:51 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
djway |
Jul 12 2016, 05:57 PM
out of stock |
djway |
Jul 12 2016, 05:58 PM
Not available per the page |
jim_hoyland |
Jul 12 2016, 06:40 PM
Get that VIN ? Group: Members Posts: 9,317 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Try a VW shop that's servicing buses....virtually the same motors IIRC
914Sixer |
Jul 12 2016, 06:42 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
What is the part #? The bughaus page is showing 0280130012 that is for a D-Jet. It is a common head temp sensor.
djway |
Jul 12 2016, 09:22 PM
What is the part #? The bughaus page is showing 0280130012 that is for a D-Jet. It is a common head temp sensor. When you click on the part to order the next page says "Not available" The part number is the same, the D and L both use the same CHT sensor. I have tried all sorts of web sites and once you click to order they are not available. |
MarkV |
Jul 12 2016, 11:46 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
jcd914 |
Jul 13 2016, 12:45 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Not to say that you don't need a CHT sensor but how did you determine you need one?
The CHT is not a common failure point and I dont think I have ever seen one thta failed such that the engine was being flooded with fuel. I would be more suspicious of the Air Flow Meter than the CHT sensor. They are known for sticking and binding. Jim |
djway |
Jul 13 2016, 12:46 AM
I have a bad head temperature sensor on my 1974 1.8 914. I called Pelican Parts and they say they are not available. My car is just dumping fuel and I cant drive it until I get a new one. Where can I find them? Thanks Dwayne After hours of searching I finally found a place that provided a new part number. Engine Cylinder Head Temperature Sensor-Bosch 802 54117 101 Around $30 It list all of the same vehicles as the old part number. Funny that all the Porsche sellers don't seem to know this. It made no sense that this many vehicles would have no supply |
djway |
Jul 13 2016, 03:22 AM
Not to say that you don't need a CHT sensor but how did you determine you need one? The CHT is not a common failure point and I dont think I have ever seen one thta failed such that the engine was being flooded with fuel. I would be more suspicious of the Air Flow Meter than the CHT sensor. They are known for sticking and binding. Jim Measured its resistance. I had another one sitting around that gave a better reading and put it in. it runs now. I want to put a brand-new unit in to get even better reading. |
djway |
Jul 13 2016, 03:23 AM
Price is nuts |
djway |
Jul 13 2016, 04:51 PM
Well, I ordered under that new part number and guess what, not available.
I finally talked to someone that actually knew about the problem at the Bus Depot. He was baffled about what to do. Every single type 1,2,3,4 aircooled and some watercooled with fuel injection use that same exact sensor. |
914Sixer |
Jul 13 2016, 08:37 PM
I do not understand what happened to all the sensors, you could buy them all day long for less than $30 bucks. I checked all my sources and they came up empty. (IMG:style_emoticons/default/headbang.gif)
Keith914 |
Jul 13 2016, 08:56 PM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
I have one recently removed from my '72, Yours for the cost if shipping and $5 for my effort to ship.
McMark |
Jul 13 2016, 09:46 PM
$30 I'll send you one of my custom ones that are better than stock.
djway |
Jul 13 2016, 11:31 PM
Lo-Fi Version | Time is now: 4th June 2024 - 06:44 PM |
