RoadGlue |
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California ![]() ![]() |
Is the handbrake clevis pin the same as the clevis that's used on the pedal-side of the clutch cable? Mine is toast, and took a bit of grinding, a vise and a punch to remove it. Needless to say, I'm in need of a new one.
Thanks, |
RoadGlue |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I made one for one car I'm working on. Bought a long clevis pin of a larger diameter than stock (hole was ovaled). Cut to length, put the new clevis in a drill and use a hacksaw blade to cut a new groove in it and then put a new circlip on it. Sounds backwoods, but it's almost indistinguishable from the stock one. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
It's a bit smaller, IRRC. The pin is the same size, but the clevis clip is smaller. The Cap'n
Lo-Fi Version | Time is now: 17th June 2024 - 05:45 AM |
