where to buy, Brake line grommets |
80cap |
Aug 14 2016, 02:18 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
914 rubber doesn't make the soft brake line grommets that secure the soft lines that attach to the hard lines that fed the master cylinder. I think they might be the same grommets as the fuel lines.
Thanks Brian |
pilothyer |
Aug 14 2016, 05:42 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
914 rubber doesn't make the soft brake line grommets that secure the soft lines that attach to the hard lines that fed the master cylinder. I think they might be the same grommets as the fuel lines. Thanks Brian Chris Foley at Tangerine Racing has the fuel line grommets, which are the same as the brake line grommets. |
80cap |
Aug 15 2016, 04:55 AM
thanks
rmdinmd |
Aug 15 2016, 11:06 AM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
http://www.pmbperformance.com/teener.html
If you are looking for the grommets that go into the master cylinder the above link is what you want. The other ones might be the where the lines pass through the body. |
Lo-Fi Version | Time is now: 9th June 2024 - 03:44 PM |
