Rear window removal, Advice for removal and replacement |
DRPHIL914 |
Aug 26 2016, 07:46 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Yes , another "help me not make a mistake when I do this " thread.
Going to be very busy tearing down the car for paint tomorrow which will include removal of the rear window as well as the front. It's in there pretty good I think. Just need to know if there are helpful hints on how to do this with out breaking anything- Thanks, Dr. Phil |
EdwardBlume |
Aug 26 2016, 07:53 AM
Make sure the window isn't falling out by itself.
Take all the trim off the inside of the window. If the seal is original, it should pop out with a push. If not, you need to thread a wire or lever a compromise in the seal. A second person should catch the glass unless you want it to drop and potentially break. Have fun! (IMG:style_emoticons/default/aktion035.gif) |
blackmoon |
Aug 26 2016, 10:01 AM
Member Group: Members Posts: 153 Joined: 27-May 08 From: Cal Bay Area Member No.: 9,106 Region Association: None |
you probably want to replace the seal between the rear window and the metal of the engine access, also 3M make s a product which provides a seal between the body and the window. This basically holds the window in place, once you remove the roll bar padding.
Lo-Fi Version | Time is now: 9th June 2024 - 05:41 AM |
