MSD 6A with Pertronix, Hook up question |
Sparky |
Apr 15 2005, 10:08 AM
Mahna Mahna! Group: Members Posts: 1,134 Joined: 21-June 03 From: Spencer, MA Member No.: 847 |
So I'm hooking up the MSD I had in my 944, this is a known good unit sent it to MSD and had it tested. Here are my questions:
I'm using a Pertronix Ignitor not points: When hooking up based on the docs from MSD I've connected the black(ground) from the Pertronix to the White wire ( points trigger) on the MSD. No spark. Tested the MSD, coil wire held 1/4" from ground and white wire tapped to ground pull white wire away nice sparkage!! Ok based on MSD notes this is a valid test and proves coil s producing spark. Am I using the wrong wire for the Pertronix? What do I do with the red wire from the Pertronix? Damn I miss the one wire hook up from the 944... My best, Mike D. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Sparky |
Apr 15 2005, 10:26 AM
A little help please... Anyone? Hello? I've got a short window to play in here as the wife is making me pack for vacation. Was hoping to wrap this up before hand.
Thanks! Mike D. |
mightyohm |
Apr 15 2005, 10:30 AM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
That sounds right to me.
Did you connect the red wire of the Pertronix to a switched 12V source? Also the coil wires for the MSD should be the ONLY wires connected to the coil. The switched +12V wire that used to go to the + terminal of the coil should now be connected to the Pertronix. The tach wire will need to be connected to the white wire of the MSD as well as a tach adapter. Did the car run with the Pertronix alone? |
Sparky |
Apr 15 2005, 10:43 AM
Ran fine with just the Pertronix. I forgot to hook the pertronix to a switched 12V. Dooh. Gonna run out and try that now.
Thanks! Mike D. |
ArtechnikA |
Apr 15 2005, 10:59 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
if we are reaching the point where people are EXPECTING real-time assistance for every weird-ass modification issue that may come up, the stage is being set for lots of disappointed customers. boys and girls - when you signed up - did you pay for the 24-hour real-time assistance package? then don't be too pissed off if you don't get an IMMEDIATE response... "lack of planning (or failure to read the instructions...) on your part does not constitute an emergency on my part..." not trying to beat you up, Mike, just a little spring-loaded to pissed off myself after seeing how big a check i have to write to the government... |
Sparky |
Apr 15 2005, 11:22 AM
Rich - Need a hug?
I knew I was pushing it a little but the wife is all over my a$$ to get out of the garage and finish packing. We head out for the 20 hour drive to Disney as soon as I get back in from the office at midnight. That now leaves me 42 minutes to pack my stuff, and then head out for the office. No sweat. After I fixed my sillya$$ed mistake it now idles much smoother and I may run it to work. Need to check the projected temps for tonight first. I've got no heat and Mass still gets cold at night this time of year. An hour and 20 miute drive on the highway without heat might get a little rough. Ohh and I got a fat refund this year! WoooHooo!!!! My best, Mike D. |
Lo-Fi Version | Time is now: 10th June 2024 - 03:30 AM |
