| mepstein |
Sep 7 2016, 11:22 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,024 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I originally started using this for my aluminum motorcycle parts but when my boss saw a 3.2 intake he asked me to send out some pieces from the shop. We just got back two 67S sand cast aluminum cases. They aren't painted but they almost look that way. The vapor blast is a pressurized wet mixture of micro glass bead, water and soap. Done in a big tank. It polishes the metal vs leaving a rough finish like regular glass bead. It's also safe for internal engine areas. No residue. The guy I send the parts to is $60/hour and the exterior of the engine case took 2.5 hours. Intakes were 1 hour for the pair. My 40 year old motorcycle parts look like new. (Except for bigger scratches).
Attached thumbnail(s) |
| rhodyguy |
Sep 7 2016, 12:57 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Those turned out really nice! Do you have to contend with the oil passage ways or do they squirt the media thru those too?
| mepstein |
Sep 7 2016, 01:22 PM
Those turned out really nice! Do you have to contend with the oil passage ways or do they squirt the media thru those too? We asked him just to do the outside of the case because ours was just for cosmetics but on my motorcycle case I had him do inside and out. It leaves the inside looking like new without any residue. He also uses a sonic cleaner so all the passages are cleaned. There are a couple people around the country but after checking them out I settled on this guy - http://noreasterblastworx.com His name is also Mark and he's in New Hampshire. He's been very easy to work with. If you do decide to contact him, he often takes a day or two to return the message. |
| Tom_T |
Sep 7 2016, 03:57 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Looks like a good answer for our aluminum fan shrouds too - in order to not get a polished look to them, in addition to engine & transaxle cases, etc.
(IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| Mueller |
Sep 7 2016, 07:03 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,157 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Parts look great....I don't like the name! Not a vapor process (IMG:style_emoticons/default/smile.gif)
Water+compressed air+glass bead ≠ vapor (IMG:style_emoticons/default/headbang.gif) |
| mepstein |
Sep 7 2016, 07:08 PM
Parts look great....I don't like the name! Not a vapor process (IMG:style_emoticons/default/smile.gif) Water+compressed air+glass bead ≠ vapor (IMG:style_emoticons/default/headbang.gif) I didn't name it. Seems to be the name used in the motorcycle/industry that makes the device. |
| r_towle |
Sep 7 2016, 07:14 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I wonder if my car would fit
| mepstein |
Sep 7 2016, 07:30 PM
Here's some of the drum brake parts I sent and one before photo.
I started researching this because the aluminum parts on my bike were heavily oxidized but the fins on the engine case and hubs made palishing very difficult. Traditional bead blasting didn't have the finish I wanted. The vapor blasting did. The Porsche aluminum turned out much brighter silver than the Italian motorcycle parts. Attached image(s)
| Mark Henry |
Sep 8 2016, 12:51 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Looks like a good answer for our aluminum fan shrouds too - in order to not get a polished look to them, in addition to engine & transaxle cases, etc. (IMG:style_emoticons/default/beerchug.gif) Tom /////// The 911 fan and the /4 fan shroud is magnesium, without a coating of some kind they will look like crap again in no time. |
| JmuRiz |
Sep 8 2016, 01:34 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,655 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Hit it (mag parts) with some gibbs and you should be good to go right?
| mepstein |
Sep 8 2016, 01:39 PM
| 914dave |
Sep 9 2016, 10:39 AM
914 Addict ![]() ![]() ![]() Group: Members Posts: 748 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States
Mark,
The intakes look great! What are you coating them with? Dave |
| mepstein |
Sep 9 2016, 11:11 AM
| mepstein |
May 30 2019, 01:13 PM
I just started working on my second motorcycle rebuild. This time, instead of sending out the parts for vapor blasting, I can do it “in house”.
First step is cleaning. The shop ultrasonic cleaner is big enough for a Porsche engine so my little 350 was easy. Attached image(s)
| mepstein |
May 30 2019, 01:14 PM
It came out of the tank clean but ugly. (IMG:style_emoticons/default/sad.gif)
| mepstein |
May 30 2019, 01:15 PM
The vapor blast machine was just serviced so 5 minutes on each piece was enough to make it pretty again. (IMG:style_emoticons/default/smile.gif)
| mepstein |
May 30 2019, 01:18 PM
@bbrock - ready for your carbs (IMG:style_emoticons/default/biggrin.gif)
| bbrock |
May 30 2019, 01:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
That's awesome! The before looks just like my carb bodies. Going to try to tear down and clean the second carb tomorrow. I need something to get my mind off the brake caliper fiasco (IMG:style_emoticons/default/biggrin.gif) |
| Nacho |
May 30 2019, 04:20 PM
Member ![]() ![]() Group: Members Posts: 224 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None
I'm in the aerospace precision cleaning business and we never ultrasonic aluminum. What you see on the surface of the aluminum are cavitation marks generated by small implosions that are super hot in excess of 300F on the aluminum when the ultrasonics are on. Excessive exposure to sonication can generate pits and even cracks on the surface of the aluminum. When cleaning aluminum and ultrasonic cleaning is desired, its best to only do small burst 15-20 seconds of sonication at a time but not to exceed more that a few minutes in total for the cleaning. |
| gandalf_025 |
May 30 2019, 04:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,537 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
There is a gentleman on the international CBX Web site
In Arizona that does vapor blasting, if you are more local to There... goes by the name noble hops I think.. |
Lo-Fi Version | Time is now: 27th November 2026 - 08:06 PM |
