| catsltd |
Sep 11 2016, 12:43 PM
Member ![]() ![]() Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
I decide to do a compression test since I am going through so much oil.
I warmed car up to about 1/4 on gauge would not go higher sitting on cold day. Petal to floor cranked 5-6 times. 1.Standard compression test cylinder 1 =110 PSI. 2. added a bit of oil cylinder 1 same test 150 PSI. Thats all i did. Seems like rings as was suggested earlier when discussing my oil usage earlier post.??? If rings are there any sort of cheap solutions.???. Car has 100,000 miles on it roughly. Thanks for any suggestions. Money is a issue. Although I am sure just like everything else,once you go to fix 1 problem on a 914,you always end up finding a few more. Car runs great,but using a lot of oil. Grant |
| porschetub |
Sep 11 2016, 11:07 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,158 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I decide to do a compression test since I am going through so much oil. I warmed car up to about 1/4 on gauge would not go higher sitting on cold day. Petal to floor cranked 5-6 times. 1.Standard compression test cylinder 1 =110 PSI. 2. added a bit of oil cylinder 1 same test 150 PSI. Thats all i did. Seems like rings as was suggested earlier when discussing my oil usage earlier post.??? If rings are there any sort of cheap solutions.???. Car has 100,000 miles on it roughly. Thanks for any suggestions. Money is a issue. Although I am sure just like everything else,once you go to fix 1 problem on a 914,you always end up finding a few more. Car runs great,but using a lot of oil. Grant I wouldn't do that test until the engine is up to full temp,what oil are you using in the engine? |
| sixnotfour |
Sep 12 2016, 12:59 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,342 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
what is a lot of oil ?? 1qurt = 1mile or.....
| Perry Kiehl Clone |
Sep 12 2016, 05:41 AM
Unregistered |
If you use a quart in 500 miles, it's time to rebuild. That's not to say it won't run OK though.
| catsltd |
Sep 12 2016, 07:02 AM
| VaccaRabite |
Sep 12 2016, 05:23 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,904 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
If you use a quart in 500 miles, it's time to rebuild. That's not to say it won't run OK though. I am using a quart every couple hundred miles. I use Bradd Penn 20/50 I think. What is a rebuild,is there a kit?? NOT GOOD NEWS. what you need on a rebuild depends on what was worn in your engine. You can probably do a top end rebuild. This means sending the heads off to have them rebuilt. Honing the cylinders (if they are still serviceable) Probably new pistons. Definitely new rings. All your money will go into the heads. Its not a job you want to do at home unless you know what you are doing. Zach |
| 0396 |
Sep 12 2016, 05:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
After reading this interesting tread, here's my.02 cents.
With 100,000 miles on the motor and if your only going to do a top end refresh. Its like taking a shower and putting back on the same shorts and possible t shirt. Point is, split the case and refresh everything. |
| catsltd |
Sep 13 2016, 07:45 AM
After reading this interesting tread, here's my.02 cents. With 100,000 miles on the motor and if your only going to do a top end refresh. Its like taking a shower and putting back on the same shorts and possible t shirt. Point is, split the case and refresh everything. I guess it all boils down to costs. It also boils down to getting screwed by local shops that dont know shit about a 1.8L motor. I am prepared to spend a bit of money,but not so someone can practice there rebuild skills on my car. If I lived in the USA I would at least have some options from the forum experts. Thanks Grant |
| DavidSweden |
Sep 13 2016, 11:15 AM
Member ![]() ![]() Group: Members Posts: 482 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
After reading this interesting tread, here's my.02 cents. With 100,000 miles on the motor and if your only going to do a top end refresh. Its like taking a shower and putting back on the same shorts and possible t shirt. Point is, split the case and refresh everything. I guess it all boils down to costs. It also boils down to getting screwed by local shops that dont know shit about a 1.8L motor. I am prepared to spend a bit of money,but not so someone can practice there rebuild skills on my car. If I lived in the USA I would at least have some options from the forum experts. Thanks Grant You can rebuild the bottom end yourse its not hard if you keep it stock. The heads will need a proffesional rebuild Go for it it will be fun |
Lo-Fi Version | Time is now: 23rd August 2026 - 09:10 PM |
