> Speedo problem
cal914
post Sep 16 2016, 01:59 PM
My speedo won't work unless I give the glass a knock or go over a pot hole on the road , what could be causing this
B
Replies(1 - 2)
6freak
post Sep 16 2016, 03:08 PM
MR.C
QUOTE(cal914 @ Sep 16 2016, 12:59 PM) *
B
are you pushing it (IMG:style_emoticons/default/av-943.gif) cables coming loose or broke JMO
MikeC
Dave_Darling
post Sep 16 2016, 03:22 PM
914 Idiot
The bits inside are gummed up.
Does the odometer still count up? If it only does when the speedo is working, then it could be a problem in the cable or angle drive or other such. Bug if the odometer goes up and the speedo needle doesn't move, something is messed up inside the speedo housing.
A VDO repair shop should be able to fix it. Or you can try taking it apart yourself and cleaning up stuff.
--DD
- Lo-Fi Version Time is now: 31st July 2025 - 08:02 AM
