What's this?, Interior light wiring? |
Ogchopsticks |
Sep 25 2016, 01:29 PM
Newbie Group: Members Posts: 16 Joined: 25-September 16 From: Tennessee Member No.: 20,429 Region Association: Rocky Mountains |
Attached thumbnail(s) |
rgalla9146 |
Sep 25 2016, 02:49 PM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Seat belt interlock.
If the car runs with that unplugged it's been bypassed under the passenger seat. |
Ogchopsticks |
Sep 25 2016, 03:07 PM
Ogchopsticks |
Sep 25 2016, 03:20 PM
Seat belt interlock. If the car runs with that unplugged it's been bypassed under the passenger seat. So a seatbelt interlock disables the car unless a passenger has put their seatbelt on correct? And bypassing renders that system useless? (IMG:style_emoticons/default/huh.gif) |
Mike Bellis |
Sep 25 2016, 03:52 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Driver or passenger. There is also a pressure switch in the seat that interlocks with the seatbelt. I have never seen one that still works.
Tburt52359 |
Sep 25 2016, 06:07 PM
Newbie Group: Members Posts: 49 Joined: 24-May 15 From: Orange County Member No.: 18,756 Region Association: Southern California |
So, a few weeks ago I had the seats out and re-connected the two plugs. To my surprise the "fasten your seat belts" light lit up. But when I turned the key, nothing. Engine did not turn over. I un plugged them and the engine started right away. Just for clarification. If I would have buckled my seatbelt, the engine would have started??
I have a 74 1.8 Thanks fellas. |
Mike Bellis |
Sep 25 2016, 06:27 PM
So, a few weeks ago I had the seats out and re-connected the two plugs. To my surprise the "fasten your seat belts" light lit up. But when I turned the key, nothing. Engine did not turn over. I un plugged them and the engine started right away. Just for clarification. If I would have buckled my seatbelt, the engine would have started?? I have a 74 1.8 Thanks fellas. Maybe. It should have. |
JeffBowlsby |
Sep 25 2016, 07:05 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
With everything connected correctly and functioning, the seat switch needs to be activated (sit in the seat), buckle the seatbelt, and turn the key. If something is amiss the engine will not start.
If for instance you put a heavy box on the passenger seat, and the passenger seatbelt is not connected, the engine will not start. The system works on my 1974 914, I have not disabled it...but I do carry a splice connector in the car for the big yella wires just in case. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
porschetub |
Sep 25 2016, 07:08 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Driver or passenger. There is also a pressure switch in the seat that interlocks with the seatbelt. I have never seen one that still works. unpicked my lower seat bases and took these strange sensor thingies out last year really don't want to carry that junk around. |
Tburt52359 |
Sep 25 2016, 07:10 PM
With everything connected correctly and functioning, the seat switch needs to be activated (sit in the seat), buckle the seatbelt, and turn the key. If something is amiss the engine will not start. If for instance you put a heavy box on the passenger seat, and the passenger seatbelt is not connected, the engine will not start. The system works on my 1974 914, I have not disabled it...but I do carry a splice connector in the car for the big yella wires just in case. (IMG:style_emoticons/default/biggrin.gif) Thx Jeff |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:54 AM |
