Building a 1.7 with Cam and carbs, Need to know head and Weber numbers! |
Garland |
Apr 18 2005, 07:47 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Some time ago I read a post that had head numbers but can't find it now . Also now I need to now what carbs I have.
I am trying to build up a rebuilt 1.7 with a 260 X 396 cam. The carbs I have are Weber 40 DCNF 101-250 4D and 102-250 4G. The number on the heads 022 101 372. 2.0 heat exchangers and a Triad exhaust. I need some help, is this all going to work ? |
Aaron Cox |
Apr 18 2005, 07:50 PM
DCNF's? intersting.... why did you choose those over IDF's?
i have no experience with the DCNF down drafts.....just IDF's |
Garland |
Apr 18 2005, 07:59 PM
I don't have any experience with them, this is just the stuff I have to use and hope it will work. |
Bleyseng |
Apr 18 2005, 08:01 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I hope you are putting larger valves in the 1.7 heads...
Garland |
Apr 18 2005, 08:08 PM
The engine has 96MM B/B kit 1700CC rings, and ballanced. The heads I belive are stock.
Lo-Fi Version | Time is now: 9th June 2024 - 10:21 AM |
