Fuel Sender Gasket VW? 914? |
Tastyplacement |
Oct 8 2016, 04:52 PM
Newbie Group: Members Posts: 39 Joined: 31-August 16 From: Austin, TX Member No.: 20,358 Region Association: MidAtlantic Region |
Here's my fleabay fuel sender gasket after two weeks (550 replica with a frankenstein mix of VW & 914 & VDO parts), I need an actual gasket:
(IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-20358-1475967137.1.jpg) Here is the sender, it's VDO and I think follows the VW 5-bolt pattern: (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-20358-1475967137.2.jpg) I just ordered a 914 gasket from 914rubber, which looks the same, but I am not sure about the bolt pattern--is the bolt pattern the same? I just need a quality part that won't corrode when fuel touches it. |
Mikey914 |
Oct 8 2016, 11:51 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Ours is neoprene, so it should hold up better.
Dominic |
Oct 9 2016, 12:24 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
That's a VW Bug sender as you most likely have a VW Bug fuel Tank in your Spyder. I think they were originally a cork gasket??
Dave_Darling |
Oct 9 2016, 01:43 PM
Yup, get a Bug gasket. The 914 sender is a tall cylinder.
--DD |
Tastyplacement |
Oct 10 2016, 02:38 PM
OK, brilliant move from 914rubber, they just shipped me the VDO/Beetle gasket even though I ordered the wrong 914 one. Should be smooth sailing from here.
Lo-Fi Version | Time is now: 11th June 2024 - 09:32 AM |
