> Which Heat exchangers ?, Go with SS or Stock
914Sixer
post Oct 31 2016, 07:56 PM
I have a set of each in good shape. The SS ones are very light compared to the stock ones. They do not have the same sound as the stock ones to me. My understanding is they are the same diameter tubes so no horsepower advantage. I will be using a Dansk banana muffler.
Thoughts (IMG:style_emoticons/default/popcorn[1].gif)
Replies(1 - 7)
Tom_T
post Oct 31 2016, 09:26 PM
TMI....
SS won't rust Mark .... ever, & if they're lighter, then you're "building in lightness" per the Porsche racing formula (as opposed to concerns over tone or sound) - so that's my 2 cents!
And they are the same diameter as stock.
Tom
Mark Henry
post Oct 31 2016, 09:36 PM
that's what I do!
If it's the same diameter it doesn't really matter, weight saving would be minimal overall unless it's a race car.
Go with the ones you like the best. (IMG:style_emoticons/default/smile.gif)
bretth
post Oct 31 2016, 10:11 PM
The usual SS exchangers will fatigue and fail over many heat cycles. If they are not new at least pressure test them for leaks for safety sake. There have been threads on here in the past showing failed SS exchangers.
Brett
jcd914
post Oct 31 2016, 10:54 PM
SSI Stainless heat exchangers have tubing with the same outside diameter as stock but thinner walls so the inside diameter is larger.
My experience is it make a difference.
Jim
IronHillRestorations
post Nov 1 2016, 05:51 AM
I. I. R. C.
The flanges that bolt to the head are way better on the stock HE's. There's probably twice the sealing surface, and they fit the exhaust ports better.
That said, I've never really had a problem with the SSI's, but I have seen a few with the mounting ears pulled off.
914Sixer
post Nov 1 2016, 06:02 AM
I agree about the mounting ears pulling off the SS. It has happened twice to me.
rjames
post Nov 1 2016, 09:29 AM
I'm made of metal
Splitting hairs. go with what you like best.
I'm running SS exchangers, but I also backdated a rusted out system from a '75.
I haven't any fitment or sealing issues. I like that they won't rust out. Both stock and SS are old and both can fail. Go with what you like.
Prices for the SS have remained constant the last 10 years so if you need the money, sell them. If you decide to go back at a later date it'll probably cost you the same to buy a set again. If you don't need the money, keep them as spares in case the stock ones rust out.
- Lo-Fi Version Time is now: 4th July 2025 - 05:24 PM
