Rocker Arm Spring Washer, Is it needed |
NJTom |
Nov 3 2016, 12:08 PM
Member Group: Members Posts: 92 Joined: 16-July 14 From: NJ Member No.: 17,643 Region Association: None |
We are assembling a 1974 2.0 motor and ran into a small problem. One side had washers which we identified as "thrust" washers. on the rocker arms while the other did not. See pictures below. Research says they were discontinued (maybe replaced in the mid 70's) can someone tell if they are needed or not? Thanks inasvance.
Attached thumbnail(s) |
bdstone914 |
Nov 3 2016, 12:17 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Yes. Porsche does not put in parts that are not needed in engines. I can mail you one for mailing cost.
NJTom |
Nov 5 2016, 08:06 AM
Thank you, would you two? As mentioned one Sid has both the other none. Interesting. And THANKS!
stugray |
Nov 5 2016, 11:22 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Another option is the solid spacers to replace the springs that come with the cam package from the type IV store.
Lo-Fi Version | Time is now: 2nd June 2024 - 01:29 AM |
