Oil Temperature Reading, 911sc Gauge |
mmascari |
Nov 5 2016, 09:30 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Does anyone know the actual oil temperature range in degrees if reading the oil temp/pressure qauge from a 911sc? I am installing the gauge in my 3.0 six conversion and interested to know the actual temperatures. For example, what is the temperature at the first line and what is the temperature at the red line?
Attached thumbnail(s) |
mmascari |
Nov 5 2016, 09:48 PM
I actually just did a search on the Internet and found a thread on Pelican. I assume the values would correspond to the image below. Assuming these are accurate.
Attached image(s) |
914Sixer |
Nov 6 2016, 06:36 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Your research is correct. Top scales should answer your question.
bdstone914 |
Nov 6 2016, 06:47 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If you look at the left edge of non temp faces you will see the temperatures which are used to calibrate the gauges.
mskala |
Nov 6 2016, 07:23 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Maybe you already know this but the sender needs to match the gauge, there
is not just one type. |
mmascari |
Nov 6 2016, 08:43 PM
MSKala that is really helpful chart. Thanks for that!
IronHillRestorations |
Nov 7 2016, 06:33 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
When in doubt check it with an IR thermometer. You can take a reading off the tank.
Lo-Fi Version | Time is now: 9th June 2024 - 05:34 PM |
