Upgraded my 914 to twin turbos! |
patssle |
Nov 10 2016, 10:09 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Twin turbo tie rods that is. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
tygaboy |
Nov 10 2016, 10:18 PM
914 Guru Group: Members Posts: 5,311 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I'll admit it, I fell for it... (IMG:style_emoticons/default/sheeplove.gif)
914-300Hemi |
Nov 10 2016, 11:16 PM
Senior Member Group: Members Posts: 1,356 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
Chris914n6 |
Nov 11 2016, 12:34 AM
Jackstands are my life. Group: Members Posts: 3,337 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
How big is the difference in feel?
mgp4591 |
Nov 11 2016, 03:38 AM
914 Guru Group: Members Posts: 5,383 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Where did you source them from? I'm planning on the same thing because the elimination of the one sloppy joint really does make all the difference.
mepstein |
Nov 11 2016, 06:23 AM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
PMB performance sells them
Yes, you need to use the thick washers (IMG:style_emoticons/default/biggrin.gif) |
jim_hoyland |
Nov 11 2016, 07:00 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I recently did the turbo tie-rod upgrade and found a significant improvement in the steering feel. When we looked over the old tie rods, they were definateky worn.... (IMG:style_emoticons/default/smile.gif)
patssle |
Nov 11 2016, 09:27 AM
Where did you source them from? I'm planning on the same thing because the elimination of the one sloppy joint really does make all the difference. Pelican also sells them. You need a special tool to remove the old ones but I used the pipe wrench in the picture and it worked fine. Also need a 32mm slim wrench to put on the turbos. I used this one (did have to grind the end down slightly): https://www.amazon.com/ABN-Clutch-Wrench-Re...+Fan+Clutch+Nut Definitely - you can tell the threaded studs are a lot longer on the turbos. |
jkb944t |
Nov 11 2016, 11:30 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I don't remember if I used the thick washers. What happens if you don't use them? Jeff B |
Chris Pincetich |
Nov 11 2016, 11:53 AM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Awesome (IMG:style_emoticons/default/beerchug.gif)
What do people do about the rubber boot? Mine don't fit right with my "twin turbos" and I think water gets in there (IMG:style_emoticons/default/mad.gif) |
Mr.Nobody |
Nov 11 2016, 12:03 PM
Member Group: Members Posts: 133 Joined: 24-March 15 From: San Diego, Ca Member No.: 18,557 Region Association: Southern California |
I don't remember if I used the thick washers. What happens if you don't use them? Jeff B I didn't. Caught major flack for it on here. Consulted with a number of 914 specialists and they said I didn't have to and they had run turbos without them in the past on the street and track with no issues. With the washers, the fit was all off. So I left them off. Only concern was being careful when installing to not crank them down so hard as to damage the rack. Flame suit on! (IMG:style_emoticons/default/fighting19.gif) |
whitetwinturbo |
Nov 11 2016, 12:48 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
.............my twin turbo fell for it too (IMG:style_emoticons/default/grouphug.gif) (IMG:style_emoticons/default/grouphug.gif) (IMG:style_emoticons/default/grouphug.gif)
rudedude |
Nov 11 2016, 02:37 PM
Senior Member Group: Members Posts: 511 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
I think it made a huge difference although I put in new suspension bushings also
PanelBilly |
Nov 11 2016, 04:51 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Fooled me too. I was all ready to see a big ass /6 with turbos stuffed in the teener
second wind |
Nov 11 2016, 11:41 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
So what are we talkin' money wise? I hear Chinese and NOT CHINESE.....do tell......thank you!
gg |
mepstein |
Nov 12 2016, 06:41 AM
jmill |
Nov 12 2016, 06:54 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Instead of ordering a thin 32mm you could just grind down a cheap 1 1/4 from harbor freight.
Attached image(s) |
dlee6204 |
Nov 12 2016, 07:41 AM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
So what are we talkin' money wise? I hear Chinese and NOT CHINESE.....do tell......thank you! gg About $200. Get the real deal so the rubber boots last. Genuine Lemfoerder can be as cheap as ~$140 so it really doesn't make sense to cheap out for the Off-brand stuff. |
patssle |
Nov 12 2016, 07:23 PM
Yeah definitely want the Lemfoerder.
Finished up my tie rods, new sway bar bushings, torsion bar adjustments, and did a home DIY alignment with a ruler and strings. Drove the car and seems to handle better and no shakes at speed. So I did something right! Will find out further tomorrow at an autocross... |
TC 914-8 |
Nov 12 2016, 08:11 PM
Senior Member Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 9th June 2024 - 01:56 AM |
