Fog light trim retainer, Fog light trim retainer |
simonjb |
Nov 16 2016, 09:26 AM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Mikey914 |
Nov 16 2016, 10:37 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Right now, only available as a used part. Try classifieds.
I'd bet Bruce Stone or Brad Mayer at 914LTD would have these. |
boxstr |
Nov 16 2016, 02:28 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
I will look at CAMP 914 today. I can add to the rubber plugs/
Craig at CAMP |
simonjb |
Mar 19 2017, 10:09 AM
Anyone found a new supply?
Dave_Darling |
Mar 19 2017, 01:46 PM
Piece #46 is literally a piece of wire bent into a specific shape. Hopefully not hard to replicate if you have a pattern to follow.
Piece #47 is a flat piece of metal with a bend in it, and possibly narrower at one end? It basically levers against the inside of the outer trim ring to hold it and the lens on. If you have one for a pattern, it should also not be that hard to replicate. I'd be tempted to just go with the Pilot fog lights, myself. --DD |
Mikey914 |
Mar 19 2017, 03:38 PM
What you are missing on both 46 and 47 is these are not just pieces of metal. They are infact springs. One loads the housing into the ring under ennsion (several clips). The other inserts in and puts a load on the inside of the retaining ring. We have blanked and made tooling to do these. Just need to find time to rund, and temper a few natches.
So yes underway, but a few weeks out. Mark |
simonjb |
Mar 19 2017, 04:53 PM
great java script:emoticon(':Qarl:','smid_7')
simonjb |
Mar 19 2017, 04:54 PM
great (IMG:style_emoticons/default/piratenanner.gif)
simonjb |
Mar 19 2017, 04:55 PM
great (IMG:style_emoticons/default/piratenanner.gif) java script:emoticon(':Qarl:','smid_7')
boxstr |
Mar 19 2017, 06:49 PM
I found numbers 46 and 47 at CAMP 914. Do you still need them?
Craig at CAMP |
simonjb |
Jun 13 2017, 05:28 PM
Sorry for the delay
Yes, I'm looking for 2 sets |
Hendy |
Jun 17 2017, 04:47 PM
Newbie Group: Members Posts: 1 Joined: 17-August 11 From: Laguna Niguel, Ca Member No.: 13,457 Region Association: Southern California |
Need to spend more time here on 914-World...thanks for the help with the fog lights!
sogabor |
May 9 2019, 04:17 AM
Newbie Group: Members Posts: 1 Joined: 9-January 18 From: Hungary Member No.: 21,775 Region Association: Europe |
Hi there!
I'm struggeling the same issue as simonjb did a few month ago. I need a few pcs. (2-3) fog light retainer springs. OEM PN#: 914 631 961 10 Do have some of you hided it in garage? I would be thankful for it! sogabor |
Lo-Fi Version | Time is now: 6th June 2024 - 08:32 PM |
