Cool app for checking different tire and rim sizes and offsets, Will they fit |
Mark Henry |
Dec 6 2016, 12:06 PM
Cool app I found for checking different tire and rim sizes and offsets.
Just plug in what you have, say 165/80-15, IIRC 5.5 inch ET40, then in the next box what you want to try on. Tells you the difference not only in size but what it will do to your speedo, etc I know this subject gets asked a lot, this should help many peeps. (IMG:style_emoticons/default/shades.gif) http://www.willtheyfit.com If the size I posted for the stock 165 is correct, a 17x7 rim ET40 w/ 205/50-17 tire runs dead center of the stock tire but is 3/4" wider each side. The 17" would be a hair shorter. (IMG:style_emoticons/default/first.gif) |
sixnotfour |
Dec 8 2016, 06:19 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I have 2 sets of these with both 205 and 225 tire sizes , fit great.. http://www2.cip1.com/ProductDetails.asp?Pr...Code=C13%2D9739 |
rhodyguy |
Dec 8 2016, 06:29 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
On a slab sided car too. (IMG:style_emoticons/default/wink.gif) wheels are rediculusly inexpense at cip1.
Mark Henry |
Dec 8 2016, 06:58 PM
(IMG:style_emoticons/default/agree.gif) I have 2 sets of these with both 205 and 225 tire sizes , fit great.. http://www2.cip1.com/ProductDetails.asp?Pr...Code=C13%2D9739 On a narrow body ???? (IMG:style_emoticons/default/smile.gif) What brand and size of tire? What did you think about the quality and weight? (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
rhodyguy |
Dec 8 2016, 07:06 PM
5.5" backspacing. The wider wheels tend not to bulge the tires.
jmill |
Dec 8 2016, 07:22 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Lo-Fi Version | Time is now: 1st June 2024 - 02:49 AM |
