New fuel pressure regulator setpoint?, Bosch 280 160 001 setpoint out of the box |
brownaar |
Dec 14 2016, 09:42 PM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
Like title says, does anyone know what the pressure setpoint is for the Bosch 280 160 001 new out of the box? Or, will it depend on the pressure it sees from the pump once it's all hooked up?
Thanks, Aaron |
Krieger |
Dec 14 2016, 11:43 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
You need to install it and measure the pressure when the car is running.
brownaar |
Dec 15 2016, 05:47 AM
You need to install it and measure the pressure when the car is running. I know. I was just trying to figure out if anybody knows if it's anywhere close to the stock 29psi right out of the box. Or, will it vary depending on the pressure it sees from the pump? Thanks, Aaron |
914Sixer |
Dec 15 2016, 06:16 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Pressure should be correct right out of the box. The real question will be what is the pressure in the fuel loop of your car. I recommend you replace all the hoses involved and the tank filter screen. Then you will have a good starting point.
BeatNavy |
Dec 15 2016, 06:21 AM
Pressure should be correct right out of the box. Yup. I seem to recall when I replaced one about two years ago I didn't have to adjust it much, if at all, to get it where it needed to be. Still need to check, but I would be surprised if it's not pretty close out of the box. |
jim_hoyland |
Dec 15 2016, 06:13 PM
Get that VIN ? Group: Members Posts: 9,313 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
2 bars IIRC (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 31st May 2024 - 07:36 PM |
