smog pump pulley on my 912e question |
rosenfe |
Dec 27 2016, 04:28 PM
Senior Member Group: Members Posts: 554 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
I will need to reinstall smog pump pulley with bracket,but need to know if I have to remove fan ,insert the drive shaft coupler to it and then re- mount fan?there is not enough room to get the coupler in there with fan in place .help needed
McMark |
Dec 28 2016, 08:43 AM
The fan doesn't need to be removed, but the bolts holding the fan also hold the smog pulley. You may need to loosen or remove the rear tin.
Lo-Fi Version | Time is now: 28th May 2024 - 07:48 PM |
