Which gaskets for 944CV joints |
john77 |
Jan 11 2017, 01:52 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Anyone know which gaskets work best between the 944CV joint to the stub axle on a 5 lug conversion?
Last time I did this I got 911 CV Joint Gaskets, (late 1975-84) Part #: 923-332-297-00-M30 from the bird and they didn't fit properly, so I ended up putting the old ones back on. This time I'm trying to not be so lazy, especially as my engine is now clean and I don't want grease centrifugally sprayed all over it. John |
914Sixer |
Jan 11 2017, 06:24 PM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
That is the gasket I am going to run but I am using 911SC stubs and hubs. I will put one up to the test tomorrow with the stub and CV.
porschetub |
Jan 12 2017, 12:29 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I'am running no gaskets and have no grease coming out ....or is it more to keep dirt out (IMG:style_emoticons/default/confused24.gif)
john77 |
Jan 12 2017, 03:44 PM
Ended up ordering part 901-332-297-00-M260. Let's see if those work. Luckily at $2.50 each it can be a mistake I can live with (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 28th May 2024 - 04:51 PM |
