Mike Fitton |
Senior Member ![]() ![]() ![]() Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest ![]() ![]() |
Have a set of center seat belts for the middle 3rd seat, had to drill out the plastic phillips head screws that were installed by the factory in the threaded anchor holes. They look smaller than the standard holes for the driver and passenger belts does anyone know what size bolts these take?
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
All seat belts in the US use a 7/16-20 thread. Or at lease most of them...
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
They look smaller than the standard holes for the driver and passenger belts does anyone know what size bolts these take? Pretty sure they are the same as the normal seat belts ... (IMG:style_emoticons/default/smile.gif) |
Mike Fitton |
Ok that is what I thought, I am going to tackle it again today, maybe didn't get all the plastic screw remnants out. I'll use a heat gun on it.
Mike Fitton |
Yep plastic sleeve was still stuck to the threads heat gun took care of that, same size bolt works. Thanks!
Lo-Fi Version | Time is now: 15th June 2024 - 07:07 PM |
