Installing 914rubber's tow bar attachment, why is nothing ever easy when I do it? |
76-914 |
Jan 20 2017, 03:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm finally posting my experience of what should have been a relatively easy peasy task. Let me say early on the Mark's bar is a work of art but my car was not. When I tried to mate the bar up with my car I immediately noticed it wasn't going to fit. Two problems were evident. 1, the spread between the attach points was about 9mm too short on my car and 2, the drivers side front attachment area as about 20 degrees off. I'll explain. Where the covers and/or bar mount you will notice the are not paralell to the ground but have a slight angle. The R side appeared to be normal but as I mentioned the L side was about 20 degrees greater.
I debated as to whether I should try to bend that area to match the other side and then trim Mark's bar to match or return the bar and make my own. I attached the left side of the bar to the right side of the car and attempted to "pry" that area down. No way. It wouldn't budge! Next I drilled a hole in the R front reinforcement piece which allowed me to place a piece of pipe directly on the raised area. I gave a few good whacks with a 12 lb sledge and still no love. Then I attached some blocks to pre-load the bar while I again whacked it. Nothing. Finally, with the blocks still attached I put a big foot on the bar as well then whacked it again. This time it moved and with another 10 or so whacks I was able to move the piece down enough to match the angle on the other side. strangely enough, once that angle was correct the distance between those attach points spread out enough that the bar now fits perfectly. (IMG:style_emoticons/default/WTF.gif) I thought I would have to trim it to fit but I it wasn't necessary. I remembered reading some other posts where Rick suggested to others that they correct "X" before they tried to relocate "Z". I'll bet I accidentally got it right. The spot welds did separate below but I welded those back up and everything is Kosher now. |
green914 |
Jan 20 2017, 03:44 PM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
Only took about 20 minutes to install mine - haven't used it yet, but I'm ready. (IMG:style_emoticons/default/w00t.gif)
914werke |
Jan 20 2017, 04:00 PM
"I got blisters on me fingers" Group: Members Posts: 10,142 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Not an atypical situation.
I've encountered a few cars where the attachment of the this style bar wasn't easy or possible due probably to "curbing", or hitting the front A-arm covers (yes behind the valance) hard enough to move the F. mount points. Rust is another ..... Ive been advising those ordering the bar I offer to remove those covers & inspect the mount points for just this reason. |
NeunEinVier |
Jan 20 2017, 05:55 PM
Member Group: Members Posts: 110 Joined: 24-December 15 From: In front of the smoke. Member No.: 19,488 Region Association: None |
If somebody has a nice length of heavy-wall tubing (square or round and perhaps 48" long), they could drill two holes through one end and use a pair of long bolts to attach it to the attachment points, and straighten the mount with the tubing lever instead of the tow bar bracket.
Call me paranoid, but I try to avoid using parts as tools. At least you know Mark's welds have good penetration, lol. |
Mikey914 |
Jan 21 2017, 10:47 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I guess any damage or distortion would make it difficult to install. These were made to dot the factory mounts so if yours have somehow moved. It may be difficult to install. On the bright side. Once installed you now have an additional support..
pjhaun |
Jan 21 2017, 04:54 PM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
I guess any damage or distortion would make it difficult to install. These were made to dot the factory mounts so if yours have somehow moved. It may be difficult to install. On the bright side. Once installed you now have an additional support.. Does anybody have the measurements for the attachment points; so I can make sure the tow bar will fit? Thank You!!!! Phillip J. Haun Oak Harbor, WA. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:12 PM |
