mtndawg |
Member ![]() ![]() Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None ![]() ![]() |
1975 originally a d-jet.
I'm studying the electrical diagram and cannot locate the small yellow wire coming from the relay board into the engine compartment. Note...not the one to the starter. I think it's for the cold start valve but I'm not sure? |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,245 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
It may not be a yellow wire, then. Wires can fade and change color over the years. Where on the relay board is your yellow wire? Are you sure it was originally yellow?
--DD |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,024 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
There is a nice yellow wire from the relay board to the double relay on a 74-75 1.8L, but not for the 2.0L.
So do you have a yellow wire that you are looking to figure out or do you not have a yellow wire and think you should have one? |
mtndawg |
I may have figured it out. It actually looks like the white wire in position 12 for the aux air valve, so I won't be using it with carbs.
Lo-Fi Version | Time is now: 1st September 2025 - 10:08 AM |
