> Handbrake lever, How to remove handbrake lever
erwindv
post Feb 5 2017, 01:28 PM
Region Association: Europe
Hello,
Installing a new carpet set, tried to remove het handbrake lever.
Unfortunately, didn't work.
Removed the locking clip for the cable (cfr. Haynes repair manual).
But the pin wouldn't come out.
How can I solve this problem?
Thx
Replies(1 - 7)
JoeDees
post Feb 5 2017, 01:35 PM
Mine was stuck too. Actually it's still stuck.
erwindv
post Feb 6 2017, 07:31 AM
QUOTE(JoeDees @ Feb 5 2017, 08:35 PM) *
Nobody any suggestion to get the pin out?
bdstone914
post Feb 6 2017, 07:49 AM
bdstone914
Support the back side and drive it out with a punch. Some one used a clutch clevis as the pin.
cary
post Feb 6 2017, 08:51 AM
What Bruce said. Maybe start with a good soaking of penetrating oil and give it a couple hours.
EdwardBlume
post Feb 6 2017, 09:01 AM
Soak it, punch it or press it. Careful with the handle though, not worth messing that up. Does the other side come apart? Can you get it through the tunnel and out?
cary
post Feb 6 2017, 09:27 AM
Kind of like what Rob said. Can you get enough slack to remove the handle with cable from the E brake cable loops coming thru the fire wall. That way you'd have it on the work bench. Much easier to work on.
EdwardBlume
post Feb 6 2017, 09:33 AM
That's right, I had the same issue....
http://www.914world.com/bbs2/index.php?sho...83&hl=brake
- Lo-Fi Version Time is now: 11th July 2025 - 05:04 AM
